Results 1 to 3 of 3
Thread: Cloudy water.
    jscott is offline ** No working email address ** jscott 0
    Question Cloudy water.
    I think my problem is caused by hard water, but here are the details.
    I recently opened my IG Pool (16x32). The water was clear. I tested the water and vound the Ph was low 6.6 or so. I added Ph Up (sodium carbonate) and the water turned cloudy with a whitish colour.
    I am thinking of using a Floculating (Aluminum somthing or other) in the hope that the stuff will precipitate out so that I can vacuum it out.
    What do you think?
    Indiana.
    Default Re: Cloudy water.
    Post test results and we can help. Without them it would just be a guess. Chlorine, pH, TA and CH at least.
    I tried using the floculating agent - Aluminum Sulfide and it is working. The recommended method is to put about 50g per 10,000 litre into the skimmer. It is supposed to form a gell on the sand filter and it seems to be working for me.
    John
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
