Thread: I don't understand?
    Default Re: I don't understand?
    I assume you have found you can post on the forum, now? I believe I updated you yesterday.
    Jun 2014
    Houston, TX.
    Yes! Thank you!
    7,600 gallon above ground Intex Easy Set model 10320 inflatable ring 18' X 48" rubber pool.
    Intex model T633 2,500 GPH single speed 1/2 hp filter pump.
    Rinz-N-Reuz Replacement Filter.
    Intex 120V Krystal Clear Saltwater System CG-28669 with E.C.O.
  1. Frustrated and don't understand
    By Deb_B in forum --cleanup--
    Last Post: 09-14-2013, 11:28 PM
  2. Help with trying to understand how to get Alkalinity lower
    By Rosie700 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-24-2012, 11:48 PM
  3. Don't understand Pump/Filter relationship
    By sublimity in forum Pool Equipment & Operations
    Last Post: 04-23-2012, 07:12 PM
  4. Maintaining FC level, help me understand.
    By freddyttt in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2009, 10:18 AM
  5. I don't understand ...
    By GolfTop in forum Dealing with Algae & Slime
    Last Post: 04-25-2006, 10:08 AM
