Closed Thread
Thread: another new user with chlorine questions
    Jun 2014
    Texas
    Angry another new user with chlorine questions
    my pool was stable at 2ppm free and total chlorine and 60 ppm cyn, 7 .4 ph. I added 1 gallon of liquid bleach and the chlorine went to near 0, I balanced the ph with borax when i opened the pool this year.
    Can anyone tell me why or how the chlorine may have gone to 0, I just added 2 lbs of hth super shock and my site glass ph/cl says I have about 1.0 ppm.
    10,000 gal 24x16x52 blue glacier above ground sunk in the ground, starbright sd-40 1hp motor, sand filter, chlorine,taylor k-2005, k-1515 on order
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    Default Re: another new user with chlorine questions
    Hi sobrien. If your CYA is at 60 ppm, then a FC level of 2 ppm is too low to properly disinfect your pool water. If the FC level went to 0, it is being consumed by biologicals, algae and/ or bacteria. How does your water look, is it clear? You need to shock (super chlorinate) your pool water until your combined chlorine levels are less than 0.5 ppm. Then bring and keep your FC at levels appropriate for your CYA level. You can find these charts in watermom's and pooldoc's signatures.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
    I just now realized that sobrien has two threads going about her pool which makes it hard to help with advice scattered. So, I'm going to close this thread and let her/him just use the other one.
    Tom, thanks for your reply, by the way!
Closed Thread
  1. new user - Super-Simple pool chemistry for Intex questions
    By jab240 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-01-2014, 05:48 PM
  2. New User, New Pool owner in Canada. QUESTIONS! ;)
    By v1rotate in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-06-2012, 04:05 PM
  3. Chlorine Question from New User
    By MrTodd in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-13-2012, 11:07 PM
  4. New user - a few questions about refinishing options
    By samtex in forum In-Ground Pool Construction and Repair
    Last Post: 07-08-2011, 11:51 AM
