Results 1 to 5 of 5
Thread: Rusty dipper?
    Jun 2014
    New Jersey
    Default Rusty dipper?
    Is it typical for the little testing dipper that comes with the R-0870 reagent to turn a rusty brown color with use? I'm guessing it's oxidation? Will that effect the test?
    Thanks,
    Splash
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    Default Re: Rusty dipper?
    I have had my current kit for a couple of years. My dipper is plastic and I'm not seeing what you are seeing. But, I wouldn't think it would affect the validity of the test, though.
    Jun 2014
    New Jersey
    Well then Taylor either changed the plastic they're using or I've got some kind of contamination. I'll take a picture when I get home.
    Splash
    If this is a new kit, you need to return it.
    If it's an old kit, you need to replace the dipper (and powder?)
    Jun 2014
    New Jersey
    I emailed in photo. It's turned into a oily black. I think it may be the dipper is coming in contact with the little foam pad packed underneath and causing some type of reaction.
  1. Pool keeps getting worse...after filling with rusty well water.
    By Jenni in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-31-2014, 10:59 AM
  2. Rusty brown spots
    By LoracRingo in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-13-2012, 07:04 PM
  3. need help with rusty well water
    By shana in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-06-2011, 08:45 PM
  4. Rusty walls
    By shadowman in forum Pool Equipment & Operations
    Last Post: 09-12-2008, 11:36 AM
  5. SWG pool and rusty screws
    By CanuckPool in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-28-2006, 11:15 AM
