I edited your post and numbered the questions to make it easier to answer them.
1. Since your pump is not yet running, I would probably add some bleach today. Just pour it slowly in front of your hose so it will mix in faster. Be careful not to splash you or your liner (if it is a liner pool).
2. You will use dichlor until you get your CYA level where you want it. After that, just switch to using bleach. For most pools, a CYA of about 50ppm works well. The connection between CYA and chlorine levels is explained here: http://pool9.net/cl-cya/
3. The info in the SS Recipe includes using bleach so that people who need a few days to get their dichlor will know how much to add. Since you already have the dichlor, go ahead and begin using it.
4. Either way is ok. If you decide to put it directly in the pool, broadcast it around instead of dumping it all in one spot. It is quick dissolving but if you notice any piles sitting on floor, just brush it around.
5. Borax can be added slowly to the skimmer while the pump is running, breaking up any clumps. Don't put it too much too fast.
6. Turn on the pump when the pool is full.
7. The pump should always be on when adding chemicals. (But, it will be ok to add a little bleach today before you turn the pump on.)
Don't worry about too many questions. That is why we are here. If you have more, ask away.
Do a lot of reading here on the forum, especially the stickied threads at the top of the various subsections. Also, read over on our sister website www.poolsolutions.com.
