Results 1 to 4 of 4
Thread: Too Much Chlorine For Dogs?
    Mar 2014
    NC
    Default Too Much Chlorine For Dogs?
    Is there an upper limit for chlorine that's too much for dogs? We have a new puppy (12 weeks) that, for the first time for a dog of ours, we have decided to teach to swim and behave in the pool. I am currently keeping the FC around 8-10 (CYA 60-70). Certainly, when I was fighting algae last month and FC was near 20, I would say levels like that may be a problem, but is it really?
    Any resource for toxicity levels for FC in pools for pets?
    Thanks!
    25,750 ga 18x36 Rectangle IG Vinyl liner; Hayward 250 sand filter; 1.5 hp pump. PF=4.4
    California
    Default Re: Too Much Chlorine For Dogs?
    Unless your dog is using the pool as a water bowl drinking a lot from it, then it should be OK. Worse than chlorine would be if you were using 50 ppm Borates and the dog was drinking a lot. The risk is still low, but it gets closer to where it could be a problem.
    15.5'x32' rectangle 16K gal IG concrete pool; 12.5% chlorinating liquid by hand; Jandy CL340 cartridge filter; Pentair Intelliflo VF pump; 8hrs; Taylor K-2006 and TFTestkits TF-100; utility water; summer: automatic; winter: automatic; ; PF:7.5
    Mar 2014
    NC
    Thanks.
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    In the summer my dogs refuse to drink from anything but the pool. They are old and healthy.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
  1. dogs and above ground pool
    By euromarek in forum Pools, Pets and Creepy Critters
    Last Post: 03-14-2012, 12:08 PM
  2. Will dogs damage vinyl liners??
    By JimCrackorn in forum Pools, Pets and Creepy Critters
    Last Post: 08-13-2006, 10:39 PM
  3. Dogs taking a dip heats them up???
    By bparks in forum General Interest
    Last Post: 06-15-2006, 02:07 PM
  4. Above ground ladder/dogs
    By bob57 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2006, 08:34 PM
