Thread: RayPak 2100 finally will not ignite....
    Apr 2014
    San Diego, CA
    Default RayPak 2100 finally will not ignite....
    It's been a little touchy lately, but now when I turn on the heater, I just get a click at 5 seconds, and a faint smell of gas. My guess is that the igniter is not working. I don't remember if it should click frequently to ignite, but it isn't. When I turn it on, it says RP 22, then 5 seconds later it clicks, and says SPK 22.
    I'm thinking the RP is Raypak, and the SPK is spark, and maybe the 22 is a code?
    plaster 20k gal kidney shaped swimming pool with spa Hayward Vac, Nautilus DE filter, Raypak RP2100 gas heater.
    May 2013
    Northwest Indiana
    Default Re: RayPak 2100 finally will not ignite....
    I have the same heater... Checked the manual and I didn't see any numerical error codes. Not sure what the "22" is. The manual does have troubleshooting info though. Might want to start there.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
  1. Raypak pool heater won't ignite
    By BPhilip in forum Pool Equipment & Operations
    Last Post: 06-03-2014, 01:03 PM
  2. Question on Raypak 2100 Pool Heater
    By Canaligator in forum Pool Equipment & Operations
    Last Post: 06-26-2011, 09:35 PM
  3. Raypak 2100 BRD error
    By swreeder in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2007, 08:04 AM
  4. Raypak 2100 w/ digital display
    By viking1 in forum Pool Equipment & Operations
    Last Post: 05-25-2006, 10:16 AM
