Fluctuating numbers
					I started battling algae on Saturday as I've previously posted - I uncovered to find algae on parts of the floor and walls but the water was generally clear.  During the "battle" process some of my numbers have fluctuated...and not the ones I expected (like Chlorine).
Here's what I've got:
5/26 - water slightly cloudy, but could see the main drain in the 8' end...this is "normal" for my pool as we have sand issues in our neighborhood.
FC 5
CC 0
TC 5
pH 7.2
Alk 90
Cal - didn't test, but it runs right at 50 normally
CYA - didn't test, but had been running right between 50-60
Temp 88
6/4 - uncovered the pool (solar cover) to find algae growing on parts on the walls and floor - water generally clear
FC .5
CC 0
TC .5
pH 7.5
Alk 110
Cal 50
CYA 50
Temp 92
At this point I ran to Wally World and picked up lots of bleach...added amount per BleachCalc to get up to 20.  Tested about 2 hours later and got 18 for FC...added a bit more and 2-3 hours later got 20. - Vacuumed & backwashed several times
6/5 A.M.
FC 18 - added bleach per BleachCalc after test
CC 0
TC 18
PH 7.5
Alk 90 ???
6/5 P.M.
FC 15.5 - added bleach per BleachCalc after test
CC 0
TC 15.5
pH 7.5
Temp 92
Vacuumed & backwashed several times again
6/6 A.M. - still some algae growth & water cloudy green
FC 16.5 - added bleach per BleachCalc
CC 0
TC 16.5
pH 7.2~7.5 (color was not either one, but an "inbetween" color)
6/6 P.M. - still some algae growth...after vacuuming water more of a cloudy white
FC 14.5 - added bleach per BleachCalc
CC 0
TC 14.5
pH 7.2
Alk 120 ???
CYA 30~40 ???
Temp 92
Vacuumed & backwashed several times...added DE in skimmer after vacuuming completed until PSI went +1 (started at 14...added until 15 - this took several cups...could be because of the size of my filter???)
6/7 A.M. - water almost completely clear...no algae growth visible - Pump PSI up to over 30! - backwashed & added more DE to raise pressure 1 PSI again.
FC 18
CC 0
TC 18
pH 7.2
Alk 120
Cal 50
CYA 50
Temp 88
The Alk fluctuation numbers are confusing me...until the "outbreak" it had been consistently at 90.  My pH has been pretty steady at 7.2-7.5...It's been 7.2 more lately though, so I'm going to add some Borax tonight.  The CYA number is bothering me too...Could this small algae outbreak have "eatten" some of it or is it more likely just slight variations in lighting (it's been back and forth from cloudy to bright sun here)?
			Sherra
Kershaw County South Carolina
(previous AG pool owner)
