Helping a buddy redo his 21,000 concrete inground pool. Removed all the concrete decking around it and old plumbing and skimmers, there where all busted from years of neglect. Had 2 skimmers, 5 returns and a bottom drain. Originally each item had its own line running into the pool house. Plan on putting back all as well, plan on running each all the way to pool house so if issues like a leak can close the valve and plug. I was thinking spend a little extra and run all lines as 2" and just size it down at the returns, for less friction loss. Is that a bad idea. Or would 1 1/2" be sufficient as each line is seperate. Some will be running probably 50' long.
Also would using two 45 fittings be more efficient than one 90 fitting.
