Results 1 to 10 of 20
Thread: First testing with K-2006
    mommak is offline Registered+ Thread Analyst mommak 0
    May 2014
    Michigan
    Default First testing with K-2006
    Okay, here's my first numbers. Any help what to do next would be great.
    Free Chlorine - 2
    Combined chlorine - 0.2
    pH- (after adding 3 drops of R-0005) - 7.4
    Total Alkalinity - 90
    Calcium Hardness - didn't turn red
    Cyanuric Acid - Did not turn cloudy
    BigDave's Avatar
    Default Re: First testing with K-2006
    FC of 2 with no CYA is plenty. It won't last very long at all in the sun - part of a day at best.
    Did you have dichlor? How are you chlorinating?
    CC of 0.2 is within the error range of the test - no problem. If you use a 10ml sample and multiply by 0.5 your reagents will last longer.
    What was the pH before adding the acid demand reagent? We seldom advise people to use the acid / base demand tests because they don't really change what you need to do. You need some acid in the pool to bring pH down if it's over 8.0. Muriatic acid is preferred as it adds nothing unneeded to the pool - be sure to read about using it safely at:http://pool9.net/ma/. Sodium bisulphate (dry acid) will also lower the pH but adds sulphur.
    TA of 90 is fine unless you find the pH is moving too quickly.
    By the way, Dave, I just looked at her previous threads. This is an Intex 18' x 48" pool, volume approx. 7000 gallons.
    May 2014
    Michigan
    Sorry about the duplicate post. I realized that my original post was not in the correct area.
    That's ok. I just locked it so we can keep everything in one place. Since Dave had already replied to this one, I figured we would just stick with it. No worries!
    May 2014
    Michigan
    BigDave
    My pH was 8.0 prior to adding 3drops of R-0005. And after going over my notes that I took, my FC is 5.0 and CC is 0.5 (forgot that I only used 10 ml for that testing).
    I am using bleach for the chlorinating. I bought the 22 lb dichlor that was recommended on here. Haven't used it yet,as it just arrived late yesterday.
    BigDave's Avatar
    Great!
    Start following the "Intex Pool Care Plan" section of the Super Simple Recipie. After using about eight pounds of dichlor, the CYA should be near 50. Don't test for CYA until you think you've used eight pounds. When CYA is near 50, you can return to chlorinating with bleach.
    Congrats on the K-2006 - The first couple times it can be a bit intimidating but it's well worth it. I forgot to mention: don't worry about the CH for now, If you don't get scale or cloudy water, you may never need it.
    @Watermom: Thanks for the volume
    Last edited by BigDave; 06-05-2014 at 02:24 PM. Reason: Add link and clarify CYA endpoint
    May 2014
    Michigan
    Thank you for all of your help. I want to be able to manage the pool on my own and not have to add another burden on my husband. I will 're-read that information and go from there.
    May 2014
    Michigan
    I have a question about part 3 on the Intex Pool Care Plan, it says to add one dose of dicholr each evening. Do I also add in one dose of the borax after the dichlor dose?
    I do this each evening depending upon my numbers?
    Intex AG, 18' x 48", 7,500 gallons,
    Intex Sand Filter-SF 20110
    K-2006 Test Kit
    The reason for the Borax dosing alongside the dichlor is because dichlor is acidic and will bring your pH down. So, to counteract that downward pull, the Borax is added. However, if your pH is higher than maybe 7.6, I'd skip the Borax that evening. After you have added a few doses of the dichlor, you'll learn how much it affects your pH and you can adjust your Borax additions accordingly. As long as your pH stays between 7.0-8.0, (best in the mid 7s) you're ok.
    When your CYA level gets to around 50ppm, you'll want to quit using dichlor and switch to just using bleach so your CYA level won't get too high.
  1. Testing cya with 2006
    By dansdad in forum DPD-FAS based testing
    Last Post: 06-01-2014, 05:29 PM
  2. Neutralize ch before testing ph on 2006?????
    By dansdad in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-04-2013, 10:47 PM
  3. Need Help Please - just got my taylor 2006 testing kit...
    By rannrich in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-16-2011, 03:41 PM
  4. Fine Tuning Testing Precedure w/ Taylor 2006
    By Gracy101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 09:36 PM
  5. Testing chlorine with Taylor K-2006 kit?
    By AndieP in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2006, 06:15 PM
