Thread: Black Algae
    gfritz1 is offline Registered+ Thread Analyst gfritz1 0
    May 2010
    Pennsylvania
    Default Black Algae
    I started a post under Dealing with Stains and Metals back on May 19th . -- Help unsure if Black Algae ?After determining it is a organic stain thought best to repost under Algae . My problem is better but by no means gone. Pool liner is 14-16 years old and has some wrinkles on bottom which makes it difficult to brush . So since initial post what have done:
    1.Shocked to above 15 three days with cya of around 55-60
    2.Added over a quart of the Kem Poly 60 and added a second maint dose
    3.Brought PH down to 7.4
    The only thing that appears to be working is a daily dose of shock (cal hypo) in a sock and attachéd to my pool and spot treat areas. They do get lighter and in some cases liner is back to initial color .
    Problem is based on size of pool not sure that will ever get ahead of it
    Could this becoming through the back side of the liner based on age and a very wet spring? If so what options exists?
    I am brushing almost every day with a scotch pad attached to a make shift holder . I vacuum every day .Run filter 12 hrs a day . Looking for suggestions . I am use to my pool being spotless and this is killing me .
    Its a vinyl inground . Ready to try anything ?
    HELP
    16x32 rectangle 23K gal IG pool; trichlor feeder; Hayward HE-65 DE filter; Hayward 1.5 pump; 12hrs; Taylor Kit - can test FC-CC-CYA-ALK-Hardness; utility water;; PF:5.2
    Been on bleach since 2012
    May 2010
    Pennsylvania
    Default Re: Black Algae
    Lots of reads but no replies .Guess Black Algae is difficult to get rid of
  1. Small Black dots in salt pool. Black algae?
    By jeanne3434 in forum Dealing with Algae & Slime
    Last Post: 04-06-2014, 04:58 PM
  2. trying to get rid of black algae
    By tulsapool in forum Dealing with Algae & Slime
    Last Post: 06-25-2013, 12:45 PM
  3. Black Algae
    By hannaswims2013 in forum Dealing with Algae & Slime
    Last Post: 05-29-2013, 01:45 PM
  4. Black Algae??
    By cmack in forum Dealing with Algae & Slime
    Last Post: 09-09-2008, 02:37 PM
  5. Black algae
    By jdw-tx in forum Dealing with Algae & Slime
    Last Post: 04-10-2006, 09:33 AM
