Results 1 to 3 of 3
Thread: Calcium Hardness increasing (just curious)
    May 2014
    Texas
    Thumbs up Calcium Hardness increasing (just curious)
    We had a monsoon that flooded our pool, so it took a couple days to get it back in order. I have been taking daily readings and noted that CH test increases every day.
    here are the last three tests
    Taylor k-2005 with K1515
    CL 12 8.5 5.4 (I have my SWCG off lowering CL as I superchlored it right after the monsoon)
    PH 7.4 7.4 7.4
    ALK 90 90 80 (played with jets to aerate (sp?) pool)
    CH 200 225 250
    CYA 80 NT NT
    SALT 3000 3000 3000
    I know that CH should be between 200-400 for plaster. Just wondering what would make it creep up, i have not added any water since the monsoon, before the monsoon CH was 290.
    13.5k gal IG pool with SWCG and intelliPH
    Default Re: Calcium Hardness increasing (just curious)
    I'm not sure why your CH is creeping up. Maybe Ben will have an idea or maybe it is just a testing issue.
    I just wanted to comment on one other thing. Don't use your SWCG to superchlorinate. That just shortens the cell life. Any time you need to shock, just use bleach and save the wear and tear on your cell.
    May 2014
    Texas
    Quote Originally Posted by Watermom View Post
    Thanks for the info, I haven't really done the bleach thing, haven't read up on it enough yet. I know there is a lot of information regarding the bleach on this site.
  1. Increasing Calcium Hardness
    By rdbrya1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-12-2014, 06:08 PM
  2. Calcium Hardness
    By kinetique in forum Dealing with Alkalinity and Calcium
    Last Post: 11-15-2012, 07:12 PM
  3. calcium hardness
    By walker1 in forum Dealing with Alkalinity and Calcium
    Last Post: 09-08-2012, 11:49 PM
  4. How much is too much for Calcium Hardness
    By Skillset in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2007, 06:49 PM
  5. calcium hardness
    By boscogabby in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-09-2006, 04:25 PM
