Results 1 to 10 of 26
Thread: Dead possoms in skimmer basket need help please
    Default Re: Dead possoms in skimmer basket need help please
    With a CYA of 40, chlorine of 5ppm is not at shock level. Shock level would be 15ppm. See the Best Guess Chart here for the connection between CYA and chlorine. http://pool9.net/cl-cya/
    May 2013
    Concord,ca
    thanks Watermom, more chlorine needed
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    May 2013
    Concord,ca
    need to add enough chlorine to bring it to 15. Pool store said 3 cases chlorine could that be right? 12 bottles of 12.5%
    Virginia
    Quote Originally Posted by dansdad View Post
    How much is in a bottle? Still sounds like a lot for your pool.
    One quart of the 12.5% should add about 2.5ppm of chlorine to your pool. One gallon would add about 9.5. Use these as a reference to figure out how much you need to add after you test, to take your chlorine level up to 15ppm.
    May 2013
    Concord,ca
    ok Watermom let me get this straight, because these numbers are what I will use from now on when testing. Lets say I have 1 ppm in my pool and I need to raise it to 10.5 then I only need one gallon? If that's the case I need to wonder why am I using so much chlorine on a weekly basis? I normally add a gallon and test and it usually comes to 3.0 So what could be going on here?
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    Here's a neat little calculator you can use to help you figure out things like that.
    http://www.poolcalculator.com/
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
    Chlorine breaks down and loses strength. The higher the percentage, it seems the faster this occurs. So, your 12.5% may not be anywhere near 12.5%. Honestly, you might just be better off buying bleach. The turnover for Walmart's bleach is so fast that it is probably much fresher and closer to what it is advertised to be than some other forms of liquid chlorine.
  1. Collar Weir Skimmer Basket - Skimmer sucking air
    By gregch in forum --cleanup--
    Last Post: 04-26-2014, 05:05 AM
  2. Poolrite Skimmer/ Basket
    By Teacchyou in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2012, 06:55 AM
  3. Need old skimmer basket help...
    By towney in forum Pool Equipment & Operations
    Last Post: 08-17-2006, 03:14 PM
  4. skimmer basket
    By cinbia12 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-14-2006, 08:50 PM
  5. Skimmer basket weights
    By The Raddish in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-13-2006, 11:16 AM
