Thread: Lower PH?
    Cleveland, OH
    Default Lower PH?
    My chlorine level was low and my PH was a bit high. I added some bleach but what should i add to lower the PH?
    Indiana.
    Default Re: Lower PH?
    Quote Originally Posted by MaxxFusion
    Muriatic acid, diluted in some water.
    Sanford, FL
    Add the acid in small doses - let circulate for about an hour and test again. Use protective gear when using it - like gloves, eye protection, and don't inhale it - I think I burned off all my nose hairs the first time I opened a bottle
    Completed 8/21/06
    14,000 gallon 3'-6' concrete pool with Diamond Brite
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Hayward Super II Pump - Cartridge filter
    See pictures here http://www.philsimmons.com/family/ga...mages&keyword=
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    If you download mwsmith2's BleachCalc it will compute how much acid to add.
    http://home.earthlink.net/%7Emwsmith...achCalc262.exe
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Cleveland, OH
    Wow thats some powerful stuff. Where can I get the acid?
    Indiana.
    Hardware store, Lowe's etc.. Paint department or concrete section.
    waterbear's Avatar
    St. Augustine, Fl
    Sometimes it's actully cheaper at the pool store. check for prices. and make sure you have REAL muratic acid. some places are now selling a muriatic acid substitute!
  1. Should I lower my pH?
    By ajb8898 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-20-2012, 11:32 PM
  2. When to lower PH
    By tnt69 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-24-2011, 03:31 PM
  3. Ph Lower after using BBB
    By Tillysaint in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-13-2007, 12:52 AM
  4. Should I lower TA?
    By shutitdown in forum Dealing with Alkalinity and Calcium
    Last Post: 06-14-2007, 07:51 AM
  5. How Do You Lower CYA?
    By cheshamjim in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2006, 01:53 PM
