Closed Thread
Thread: Gravel level with respect to laterals: TR140C Penair Sand Filter
    Apr 2014
    Minnesota
    Default Gravel level with respect to laterals: TR140C Penair Sand Filter
    I am installing a Pentair TR140C which specifies 275# of 1/4 to 1/8" dia pea gravel. What I find is that, when wet, this amount just matches the height of the top of the laterals. Is this the right level, or should be laterals be covered to perhaps an inch or should they be exposed? The sand will go above this obviously, leaving the needed free board of 13.5"
    Default Re: Gravel level with respect to laterals: TR140C Penair Sand Filter
    Please do not double post the same question in more than one place on the forum. It is easier for people to help if all the replies are in the same thread. I am going to lock this thread and let you use the other one you started.
    Good luck!
Closed Thread
  1. Pea gravel?
    By rds371 in forum Pool Equipment & Operations
    Last Post: 09-03-2011, 06:36 PM
  2. gravel in sand
    By mspool in forum Pool Equipment & Operations
    Last Post: 04-25-2011, 07:24 PM
  3. Is there any way to pressure test laterals
    By nicole12 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2007, 08:58 PM
  4. media level in a sand filter tank
    By ScottS in forum Above-Ground Pool Construction & Repair
    Last Post: 03-25-2007, 12:12 AM
  5. Laterals in Sta-Rite System 3 sand filter
    By Area Man in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 09:00 AM
