Thread: Vacuuming issue
    NY, USA.
    Default Vacuuming issue
    Whenever I vacuum my pool with 45 minutes there is a bunch of dirt back in the middle. What am I doing wrong?? Thought it was the filter, but I just installed a new Hayward cartridge system. This happened when I has a DE filter too. Help!!
    Default Re: Vacuuming issue
    What is most likely happening is that as you move the vacuum head, you are stirring dirt up into the suspension of the water. Then, later as the water quiets back down, the dirt falls back to the pool floor. I see the same thing happening in my pool if I get in too big of a rush as I vacuum. You have to move it very, very slowly so you don't stir it up.
    NY, USA.
    Thanks I will try to move really slow & see what happens
  1. vacuuming
    By kecsmom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-19-2007, 11:37 PM
  2. High CL & Vacuuming
    By fuelman in forum Dealing with Algae & Slime
    Last Post: 09-18-2006, 11:08 PM
  3. Vacuuming
    By Rangeball in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-22-2006, 08:55 PM
  4. Vacuuming problem...
    By lindamom25 in forum Dealing with Algae & Slime
    Last Post: 04-01-2006, 11:27 PM
