Welcome to the Pool Forum!
We really can't give good advice without some good testing numbers taken with a drops-based kit. The kit we recommend is the Taylor K2006 or 2006C (better buy). It isn't available locally but you can get it through our Amazon test kit link: http://pool9.net/test/
In the meantime while you are waiting for that great kit to be delivered, see if your Walmart has the 6-Way kit (NOT the 6-Way test strips) or if not, get a cheap OTO/Phenol Red kit (yellow and red drops). Test and post your results and then someone here can try and advise you on clearing it up.
Also, tell us what size your pump is and what type and size of filter you have. You should be running the pump 24/7 while you are trying to clear the pool, cleaning the filter as needed.
