Another quick question. ..... my cya was 100+ and water looked a little cloudy. From what I understand those cya levels don't allow the chlorine to do its job effectively so I'm trying to stay ahead of the curve so to speak and prevent an algea outbreak. I believe i made a mistake using Dichlor to maintain the chlorine levels instead of bleach. I didn't use Dichlor all the time to bring up the chlorine levels but apparently I did use it too much. So I drained 3/4 of the pool and am going to stop adding Dichlor when I get to about 40 - 50 ppm and then switch over to bleach. I know if my cya drops I need to dose with Dichlor but i wasn't clear on what the ideal chlorine level should be. I just want to make sure I'm not missing anything else and I get it right. Thanks in advance.
