There are a couple pump lines for AG pools that I would recommend:
Hayward Matrix
Pentair OptiFlo
Pentair Dynamo
3/4 HP to 1 HP two speeds
I think all are good pumps but I think the Matrix is a slightly better housing design that protects the bearings from moisture a bit better than the other two.
Mark
Here's the Amazon start page link.
http://poolforum.com/amz/
It doesn't matter how much water will "turnover". Pump run time should be mostly independent of turnover or flow rate.
The reasons to run a pump and the time taken to do it:
Chlorination/circulation - Manual dosing ~ 30 min, SWGs require more time.
Skimming - Most skimming occurs in the first hour, after that only what falls in the pool.
Auto Cleaner - I find only 1 hour per day is required but you may not even have one so this is not even a consideration.
So mainly pump run time is just to get the debris out of the pool and not much more. Chlorination and circulation can happen pretty quickly.
I have a 20k pool and run for 1 hour on high and 3 hours on low speed per day but that is mainly because I have an SWG. In terms of turnover, that is less than a 1/2 turn per day.
You might want to read the pump run time study article in my sig.
Mark
I read this once when I first joined, and forgot you had this posted.
After reading your pump information, I set my timer to run 1 hour from 5-6am so I can clean the basket before I leave for work;
1 hour from 3-4 pm when I get home from work.
1 1/2 hours from 8-9:30 pm when I add my chemicals.
3 1/2 hours a day on low speed....
Keeping my numbers right, will see how that works out.
Straightleg
