Thread: O - ring lubrication
    Pittsburgh, PA, USA.
    Default O - ring lubrication
    What should you use? I've always thought of petroleum jelly -- but realize that may deteriorate the o-ring. I've read other posts mentioning Silicon - but I only see that in an aerosol spray at Lowes. The pool stores sell Jack's lube -- but they are $10 for a very small tube - and I also want to lubricate other stuff as well - ( so I'm looking for something bigger).
    Any recommendation for something at HD or Lowes? ( On a side note: be careful using keyword from this post in a google search at work - I was surprised at the results -- I guess I should have thought about it first :-)
    Default Re: O - ring lubrication
    I also heard Vaseline cound be bad so I avaoided it. The Jack's products all seem pricey to me but seem to have a good reputation. I bought another brand at the pool store for around $4 but don't recall the name. Lasts a real long time so even the Jack's is not that bad in the total realm of pool ownership expenses.
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Used 2 kinds of silicone lube. One from a marine/boat dealer, but I can't remember the name. The one I use now is called Alladin Magic Lube II, 1oz vial $4.99 @ pool store. I grab a few each time I go in there. It's seems pricey to me, but convenient.
    CaryB
    Go 'Canes!!!
    JJ in Tx is offline ** No working email address ** JJ in Tx 0
    Spring, Texas
    this is the stuff that has been working for me
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Any o-ring lubricant will work...you can get it anywere they sell plumbing stuff (ACE Hardware, Wal-Mart, Lowe's, Home Depot, etc.). Usually near the o-rings. It's not expensive $1-2 per tube and it should last a while. I think sometimes it's called plumbers lube or something...it'll say right on it that it's for use with o-rings though.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
  1. Ring Pool
    By betolley in forum Intex-type Pool Setup & Operations
    Last Post: 07-09-2012, 12:35 AM
  2. Trying to replace o ring
    By Vykke50 in forum Pool Equipment & Operations
    Last Post: 07-20-2011, 10:04 PM
  3. Replacing an O-ring
    By anixon7 in forum Pool Equipment & Operations
    Last Post: 07-01-2011, 06:40 PM
  4. How to get rid of a Sooty Ring ?
    By AndyT86 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-10-2007, 07:24 PM
  5. Sunscreen ring
    By cajunfla in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-15-2006, 08:28 AM
