Thread: Tracking down a potential leak
    May 2010
    Illinois
    Default Tracking down a potential leak
    I'm trying to track down a leak that, so far, I can't figure out. The pool is rectangular 13' x 24' concrete that's about 45-50 years old. There is 1 skimmer and 1 return - both on the same 13' side and about 8' apart.
    When I opened the pool for the year things seemed to be fine, although the day after i opened it (or maybe it was the day I opened it - it's a couple weeks ago) the water level dropped a LOT in a short period of time - way more than normal. I couldn't find any problems and it didn't happen again, until today.
    The "only" thing that changed today is that I installed an eyeball (large size opening) in the return outlet. After that, the level dropped. With the amount of water I lost I'd expect to find a soggy spot on my lawn, or some sign of water somewhere, but I didn't.
    The return isn't the original one that was installed with the pool, or it's been repaired at some point, because the deck concrete over where (I assume) the return piping is has obviously been replaced and has sunken some (maybe 3/4". I don't think it's sunk enough to have wrecked the pipe.
    I'm also assuming that it's not a suction side leak sine I'm not getting any bubbling in the return water unless the water level drops enough for the skimmer intake to run low.
    One additional note is that the main drain in the pool has been cemented shut.
    I've currently got the pump shut off, and haven't lost any more water. I'm checking the evaporation rate w/ a bucket on the steps but don't think that's it since the water loss isn't happening overnight. I've also checked any suspected spots on the walls w/ dye and can't find any wall leaks.
    At this point I'm looking for ideas on figuring out what's going on without digging up the lawn or concrete.
    All thoughts are welcome! My sincere thanks for any help.
    May 2010
    Illinois
    Default Re: Tracking down a potential leak
    Update: the water loss with the pump off overnight and on today was minimal. I reinstalled the eyeball and lost 1/2" of water in 1 hour. When I installed the eyeball, the pump pressure went up 3 or 4 psi.
    So, after looking at some potentially related posts. I'm wondering if I could have a cracked pipe. When I install the eyeball and the pressure increases, then the crack opens up wider and leaks more water. I remove the eyeball, the pressure drops enough for the crack to close, and I'm not leaking enough to notice.
    I'm assuming it's gotta be on the return side
    Is this a possibility? If so - how in blazes to I find the crack?????
    With this behavior, and no air in the lines, I'm assuming it must be on the return side. Right??
    Additional info: 24' x 13' I-G concrete pool w/ sand filter
  1. Above Ground Pool - Potential Moat
    By hudson.bh in forum Above-Ground Pool Construction & Repair
    Last Post: 07-07-2010, 09:56 AM
  2. Free Pool Test Tracking Software!
    By errodr27 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2009, 02:18 PM
  3. Oxidation Reduction Potential -- HELP
    By hamop78 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-07-2006, 10:35 PM
  4. Potential Water Problems?
    By gwrace1 in forum Dealing with Algae & Slime
    Last Post: 03-27-2006, 04:56 PM
