For every 10 ppm Free Chlorine (FC) added by chlorinating liquid or bleach, it also increases sodium chloride salt by 17 ppm after accounting for chlorine consumption/usage. So if your daily chlorine usage is 2 ppm FC, then the salt level will increase by around 100 ppm per month if there were no water dilution. Note that ANY source of chlorine will increase the salt level because chlorine becomes chloride salt when it gets used/consumed. Stabilized chlorine (e.g. Trichlor and Dichlor) increase the salt level at half the rate (so around 50 ppm per month), but they increase the CYA level as well (at around 36 ppm CYA per month for Trichlor and 55 ppm CYA per month for Dichlor). Calcium hypochlorite (Cal-Hypo) increases the salt level at a rate in between these two, but it also increases the Calcium Hardness (CH) level (at over 40 ppm CH per month).
