Thread: Closing Pool for extended time
    Default Closing Pool for extended time
    I have to close my pool early this year and possibly keep it closed next year as I won't be at my home in the summer.
    I wanted to get a safety cover but I don't think that will keep algae from growing. So, I was thinking maybe get a safety cover and throw a regular pool cover over it, so that I will be covered on the safety end and also keeping it from turning in to a sea of green.
    What is the best way to close your pool long term for a season or two- for safety and condition of pool. I live in Michigan and have an inground pool.
    Thanks!
    Elle
    Default Re: Closing Pool for extended time
    I don't think you can prevent algae from growing if you leave the pool closed THAT long. But here's how I close:
    1) get the water PERFECT and clear and raise FC to shock level. If it's going to be warm for a while, I'd consider raising CYA levels to 60 or 70 ppm and using 20ppm as my FC shock level.
    2) add an entire quart of Polyquat 60% algaecide (that's a type, not a brand. If it has "Poly....<something>...60%" and nothing else as the ingredients, that's the stuff, no matter what they call it.)
    3) wait 48 hours. FC will drop precipitously from the Polyquat--that's OK and normal.
    4) run the FC back up to the shock level for your CYA.
    5) Close.
    The only thing I see you can do is add more polyquat--two to 3 quarts total, but no more. It should get you through the winter with clear water.
    But I think it's a crap shoot either way, since it sounds like you will have NO maintenance on your pool for a year.
  1. first time pool owner and first closing (still with questions)
    By rannrich in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-14-2011, 05:30 PM
  2. Closing pool for first time
    By elsie in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-26-2011, 12:13 PM
  3. It's Almost Closing Time Again
    By CarlD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-03-2007, 01:46 PM
  4. Help with 1st time pool closing...
    By mariner09 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-06-2006, 06:53 PM
  5. Closing IG for the first time
    By nyjobz in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-15-2006, 10:11 AM
