Results 1 to 10 of 20
Thread: Cloudy After Cleaning
    May 2014
    S California
    Default Cloudy After Cleaning
    I am new to having a pool and know practically nothing. After the pool guy comes to clean the pool, the water is very cloudy for a full two days. No algae problems. Also, the sides of the pool are slimy and when you rub against the side a white substance comes off. What the heck is going on? I'm never home when pool guy is here. Pool guy comes once a week. Any help would be most appreciated.
    Default Re: Cloudy After Cleaning
    Without having any good water testing results taken with a drops-based kit, we can only guess. But, if the pool sides feel slimy, then at the very least, you have an algae bloom waiting to happen.
    May 2014
    S California
    Thank you for the reply Watermom.
    Let me explain a little more about the sides. When you rub the sides of the pool with your fingers it feels slimy and a white substance comes off and disperses in the water leaving a white cloud for a moment. Where you rubbed the slimy part it then feels like normal plaster. This has been going on for some time and there has never been any sign of algae. The weird cloudiness of the water only happens after the pool is cleaned and takes two full days to recover. Seems to me the water should be sparkling clear after cleaning. The filter pump is set to run for four hours everyday. Maybe thats not enough.
    Sounds like you might need to have a talk with your pool service and get some details about what they are doing. As far as pump run time goes, 4 hours per day may not be enough. Probably more like 8 hours per day. If you are having cloudiness issues after they are there, perhaps you need to run the pump 24/7 for the next day. But...... you really need to find out what is going on. I'd be concerned if my pool was only getting attention once per week. Are you saying that testing and chemicals being added is only happening once per week?
    Maybe somebody else has some different ideas.
    May 2014
    S California
    Thanks again Watermom! Yes, pool service is once a week. So maybe I should do some testing on my own during the week. Its not like the pool came with instructions when I bought the house. I'm just going by what pool guy told me. After cleaning the water is so cloudy that you can't even see the bottom of the pool. I will extend the pump time. Do you run the pump longer during summer season? Sounds like I need a new pool guy!
    Maybe you can be the pool guy! It is not that hard and really doesn't take that much time or effort if you keep on top of things. I'm not sure anybody can help you here on the forum to figure out what is going on with what your pool guy is doing since we have no details of what he is actually doing. But, if you want to do things on your own to take care of your pool, we can definitely help you with that. Let us know if you want to go that route and someone here can help you get started.
    Go ahead and read a lot of the posts here on the forum, especially the stickied threads at the top of each section of the forum. (Until your registration is completed, you will have to log out first to be able to see the rest of the forum, however.) Also read over on our sister website www.poolsolutions.com. You'll learn a lot.
    May 2014
    S California
    Ha Ha! I think you might be right!
    Maybe I can be the pool guy. As my dad used to say, "If you want something done right, do it yourself". I just bought the house and am still unpacking and a little overwhelmed, but I am always up for a challenge. I already reset the timer to run the pump 9 hours a day during daylight hours. Will get a brush for the sides this weekend and get a testing kit. And probably a new guy until I get up to speed.
    Thanks again.
  1. after cleaning my DE
    By vinper in forum Pool Equipment & Operations
    Last Post: 06-19-2013, 10:33 AM
  2. From cloudy green to cloudy blue
    By Dydylynn in forum Dealing with Algae & Slime
    Last Post: 06-10-2012, 05:09 PM
  3. Cloudy ,Cloudy,Cloudy... for a week now.
    By uwinsome in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 05:55 PM
  4. Phase Two: Cloudy water, cleaning out the crud, etc.
    By Nebuchadnezzar in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-27-2011, 09:18 AM
  5. cleaning help
    By LazyLgrecian in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-09-2007, 08:10 PM
