Thread: water problems
    Default water problems
    we just set up our new AG pool a week ago. I followed the instructions as per our pool store. Add stabilizer, then shock and let run for a few days then add some pucks to the clorinator. Then wait another day and bring in a sample. Well the hardness was low (as expected) but the ALK was doing some weird stuff. They tried to test it but the sample turned yellow???? So they had me bring the hardness up from 20 and add some alk increaser. Well I tested it with my taylor kit tonight (just the alk and PH) Ph was a little low but as with our hot tub I try to get the alk in check and the PH usually falls into place. Well my Alk test went yellow again. I do the same as with my tub. And instead of going from green to red it gos from green to yellow? I am very confused. Any reason why? This is city water. My tub is usually low in ALk and Hardness and thats it.
    Default Re: water problems
    We really need some testing numbers to know what is going on. Also, specifically (ingredients) what you have added. Then somebody here can try and help. Also, volume of the pool.
    The alk test can suffer interferance from high chlorine levels. One of the indicators in the indicator solution will bleach out causing the test to turn from blue to yellow instead of green to red. Taylor suggests adding more of the first reagent (sodium thiosulfate) to neutralize the chlorine. What are you FC and TC readings?
  1. Pool water problems
    By SWTREGO in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-25-2012, 03:12 PM
  2. water problems
    By tshirt25 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2010, 04:21 PM
  3. Hi New Here!! Having green/cloudy water problems! HELP!
    By poolmom06 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2006, 12:29 AM
  4. Problems with well water
    By Michaela521 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-21-2006, 09:06 PM
  5. Potential Water Problems?
    By gwrace1 in forum Dealing with Algae & Slime
    Last Post: 03-27-2006, 03:56 PM
