I started reading this website last year and implemented the method last year. This is the first time I have posted though. We have had a time with the pool this year. We opened the pool in mid March and it was only slightly green. We shocked it using bleach and ran the pump when the motor died after 12 hours. The pool company told us they would be out in a week to fix it. Two weeks later the pool company still hadn't shown up, so my husband replaced the motor himself because our pool was definitely a green slime pit by then. Reshocked with bleach and added some chemicals. The pool was just turning blue (about 3 days of pump running) when the wiring went out. (yes! Only our kind of luck!) One week later, the wiring was fixed, the pool was reshocked (because it was once again a slime pit) and then...IM NOT KIDDING... It sprang a leak. Two days in hot heat caused it to turn green again. Now, everything is hopefully fixed! Yes, it's been shocked again. Here are my test results based from my Taylor drop kit: FC 8 (shocked last night - results from this morning) pH- 7.4. TA- 50. CYA 40. Vinyl liner. In ground pool. Approx 24,000 gallons
The pool is blue but very cloudy. We are running the pump 24/7 with frequent back washing. Just added a sock. So my question is: Will this clear it up? We are on day 3 of blue cloudy water with no improvement. I'm thinking the cloudiness is all the algae that we killed several times without being able to circulate and filter. Do I flock it? Do I turn the pump off for a while? Do I keep shocking it? What's my next step? Thanks in advance for the help!
