Results 1 to 10 of 10
Thread: Need some advice before I take apart my pump's plumbing
    Baltimore, MD
    Default Re: Need some advice before I take apart my pump's plumbing
    Thanks Carl! 2 questions
    A) I'm going away for a few days. Is there anything I can try as a stop gap while I'm away? Silicone, plumbing cement?
    B) any chance the pump is louder then normal due to this leak?
    48x14 rectangle in-ground concrete pool, 29k gallons, Taylor K-2006, 8.25% Clorox
    DE Filter Pentair FNS Plus FNSP60 (filter area – 60 sq ft, GPM 150, diameter 21.5”, turnover capacity 86,400 per 12 hours)
    Pump 1HP Pentair WhisperFlo high performance
    SWCG Zodiak LM3-24 (24 grams of pure chlorine per hour)
    Booster Pump Polaris Halcyon PB4-60Q
    "No pool store junk goes in my pool"
    1) I don't know--it's a fitting under pressure.
    2) It's possible but the pump may not be sitting on its base well.
  1. Pump Replacement Plumbing Question
    By DFS12 in forum In-Ground Pool Construction and Repair
    Last Post: 04-19-2014, 03:55 PM
  2. New Pump and Plumbing question
    By jefflj98735 in forum Pool Equipment & Operations
    Last Post: 03-26-2014, 08:01 PM
  3. plumbing question about a Pentair Intelliflo pump
    By jamesdean in forum Pool Equipment & Operations
    Last Post: 08-28-2011, 06:51 PM
  4. Pump plumbing - Straight Pipe Important???
    By jaimslaw in forum Pool Equipment & Operations
    Last Post: 05-22-2011, 10:18 AM
  5. Cementing around the pump PVC plumbing
    By beary in forum In-Ground Pool Construction and Repair
    Last Post: 06-06-2006, 07:57 PM
