Results 1 to 4 of 4
Thread: BBB Method
    May 2014
    SW USA
    Default BBB Method
    How to start my pool off with the BBB method? Its a 5,500 gal above ground vinyl pool.
    Default Re: BBB Method
    Ben has a sticky thread on how to start Intex pools. Those directions should be perfect for you.
    . . . membership updated.
    The "Super Simple" recipe applies to freshly filled vinyl pools that do NOT have metals in the fill water, and can be found using this link: http://pool9.net/ssr/
  1. help with bbb method
    By clayboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-20-2012, 05:46 PM
  2. Why BBB Method?
    By brittmer in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-27-2007, 10:08 PM
  3. What is the BBB method exactly?
    By sdmanship in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-28-2006, 03:41 PM
  4. BBB Method
    By fritochiprt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-15-2006, 06:46 PM
  5. The B method.....
    By matt4x4 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 12:34 PM
