thanks for getting back
13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
I only trust the k-2006 titration is better for me
Once they are dissolve in the pool they are fine, but never EVER mix them! (can you say "kaBOOM!"?)
No Carl I was not going to mix just add slowly one at a time and wait a few between adding. Thanks much
If you add bleach to gain chlorine, why would you want to add cal-hypo afterwards? As a source of chlorine, you wouldn't need to use them both on the same day. When I said that many people use both, I didn't mean in the same day as that is not needed. What I meant was that some people might use bleach most of the time and then only use cal-hypo occasionally instead of bleach or vice versa. Does that make more sense?
yes it does, I'm experimenting a little. I bought the cal hypo and I had a lot of bleach. I'm just keeping my eye on the chlorine levels closely. I know Big Lots bleach is around 2.7 strength which is nothing BUT the calculator has a place to put that amount in which is great as their bleach is so cheap. Time will tell
Remember: for 2.7% bleach to be "cheap" it must be no more than 30% of the cost of 8.25% bleach. Otherwise it's actually more expensive--when you consider how much you need to get the same chlorine level in your pool.
Now that makes sense
