Thread: Newbie here, 1st time pool owner
    May 2014
    Southeast Louisiana
    Default Newbie here, 1st time pool owner
    We just bought an above ground 22' round, 52" deep pool. Luckily, we found your forum immediately. It was extremely helpful! Pool's up, water's crystal clear (@ 4 bags shock, pool currently has 24ppm stabilizer; pH is 7.2; chlorine at about 4ppm)... Just waiting for it to warm up a bit more before jumping in. Question now... what do we do next? So, if 1 dose=1 1/2 cups of bleach for our pool size, how much will this one dose raise the ppm of chlorine? And, (understanding that we need to test daily) how often should we expect to be adding bleach or shock?
    Default Re: Newbie here, 1st time pool owner
    One gallon of 8.25% should raise your FC by about 7 1/3 ppm.
    How did you get a CYA reading of 24? The test can't distinguish readings below 30ppm. Also, what kit are you using?
    Until you get your CYA reading to around 40ish, you may need to test twice per day to maintain a chlorine reading but then should be able to go to testing and dosing in the evenings only. Keep an eye on your pH. If it drops lower than 7.2, add a little Borax to bump it back up.
    Congrats on the new pool and welcome to the Pool Forum! Let us know if you have more questions.
    . . . membership upgraded.
    Since your pool is freshly filled, you have the option for using the Super Simple Recipe => http://pool9.net/ssr/
    One key point about pools: it's much, much easier to AVOID problems, than to fix them. New pool owners commonly get into trouble when
    1. It rains, and they slack off pool care. When they remember to start back, algae has gotten a foot hold.
    2. They go on vacation. That one's tricky. Ask once you know more.
    3. They get 'pool-stored', spending bunches of money to screw up their pool, and then more to fix it.
    Good luck!
  1. 1st time pool owner
    By becka'sworld in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-13-2013, 11:09 AM
  2. G'Day from first time pool owner
    By FrankToil in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2012, 02:19 AM
  3. New pool owner for the second time...
    By lstinthot in forum Dealing with Algae & Slime
    Last Post: 08-28-2011, 02:44 PM
  4. first time pool owner needs help, please.
    By sneal in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-28-2011, 05:56 PM
  5. 1st time pool owner
    By hamiltonmike in forum Above-Ground Pool Construction & Repair
    Last Post: 05-23-2010, 11:22 AM
