Either go with ordinary chlorine--you don't even need an automatic chlorinator, adjustable floaters do the same job for $15--or go with an SWG. SWG uses salt to generate chlorine because salt is...Sodium Chloride. As for salt water eating your pool, it will be FAR less salt than the ocean. In fact, you may not even be able to taste the salt in the water.
