I went back and checked and they are 128 oz and 8.25%, that was how I came up with it (I did say 6% earlier but after you questioned it I doubled checked and it was indeed 8.25%). So at 128 oz jugs each 8.25% bleach should be 3 3/4 gallons = 15ppm.
If your pool is not green or cloudy, then I wouldn't worry about running the pump 24/7 right now. But, I would run it for several hours at least after you add the bleach to let it mix in well. Maybe at least 4 hours or so.
But, I still am not following your math. 3-3/4 gallons of 128 oz.jugs is 480 oz. which will add around 11ppm of chlorine.
Are they 96 oz or 128oz jugs? Are they 6 or 8.25%?
16x32 in-ground rectangle | chlorine pool | vinyl liner | k-2006 test kit
Now, you've got it! Good luck!
Thank you watermom!
You're welcome!![]()
