Thread: intex on concrete
    Jun 2013
    usa
    Default intex on concrete
    Im having a pad poured for my 14' ultra frame. pad will be level,checked with a water level. I cant find any info on setting up on concrete. how thick should the pad be. what is needed under the liner and anything else I might need to know.
    the pool is only up in the summer then removed for winter.
    thanks for the help
    Default Re: intex on concret
    I don't know how thick the pad should be--in part I think it depends on what's UNDER the pad. Intex used to sell a polyvinyl tarp, 16x16, that you put down first before you erected the pool.
    BigDave's Avatar
    A thin (1/4") layer of foam insulation on the pad should help protect the pool from sharp irregularities in the concrete surface.
  1. concrete bottom pool with stainless sides, sealant for the concrete/wall joint?
    By kentuckynet in forum In-Ground Pool Construction and Repair
    Last Post: 04-14-2014, 04:21 PM
  2. concrete deck mix?
    By jdolby in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2012, 03:28 PM
  3. What concrete product should I use?
    Last Post: 06-04-2012, 10:35 PM
  4. Concrete on Liner
    By CJDahl in forum In-Ground Pool Construction and Repair
    Last Post: 08-25-2006, 07:59 PM
  5. cracks in concrete
    By pc boy in forum In-Ground Pool Construction and Repair
    Last Post: 07-19-2006, 11:36 AM
