Results 11 to 15 of 15
Thread: Season Startup
    Default Re: Season Startup
    No way to predict how long it will last depends on how often you test and where you store it. Plus, you'll probably need to replace some stuff that you'll use up faster than others like the CYA test reagent. I typically just use an OTO/Phenol Red kit (yellow and red drops) for daily testing of chlorine and pH and use the big kit occasionally.
    I can't say about the PS233. You can test with it and with the new kit and compare results to see if any of it is still good.
    MD.
    Thanks guys... Just got the K-2006C kit
    Here are my latest results
    FC 2.0
    CC .5
    PH 7.6
    TA 60
    CH 150
    CYA 35
    Water is clear. Heavy Rain is expected tomorrow. I have noticed some black algae spots on the bottom and plan on adding 2 bottles of 8.25 bleach this evening. Any other suggestions would be appreciated.
    Baltimore, MD
    scrub the algae with a brush before you add the bleach. Will help kill the stuff.
    48x14 rectangle in-ground concrete pool, 29k gallons, Taylor K-2006, 8.25% Clorox
    DE Filter Pentair FNS Plus FNSP60 (filter area – 60 sq ft, GPM 150, diameter 21.5”, turnover capacity 86,400 per 12 hours)
    Pump 1HP Pentair WhisperFlo high performance
    SWCG Zodiak LM3-24 (24 grams of pure chlorine per hour)
    Booster Pump Polaris Halcyon PB4-60Q
    "No pool store junk goes in my pool"
    MD.
    Morning everyone...
    Just picked up some PoolBrand Shock at Sams Club and want to focus on my CYA and FC. How much do I add initially ?
    My CH also seem low. Any thoughts on that ? or my other numbers
    Thanks everyone for their help
    Ollie
  1. Swim season is almost here!!
    By aylad in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-29-2011, 01:50 PM
  2. Another Season Ends... :(
    By CarlD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-14-2010, 11:23 AM
  3. Another swimming season done
    Last Post: 10-16-2008, 12:25 PM
  4. 1st Readings of the season :)
    By ellenicol in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-29-2008, 07:37 PM
  5. Aquarite SWG 3rd season
    By Number6 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-10-2007, 04:19 AM
