Thread: above ground pool center drain decision
    Default Re: above ground pool center drain decision
    I'll let someone else advise you about the logistics of install but ....... personally, I wouldn't want a main drain in my 27ft AG pool. It is just another place that can potentially leak. Just my $0.02.
    Welcome to the Pool Forum, by the way!
    BigDave's Avatar
    I kinda' wish I had installed a main drain - I have to siphon water below the skimmer when I close and it takes quite a while. I think that you'll need two drains far enough apart so that a swimmer can't get trapped on both.
  1. New to Forum and in process of moving AG Gibraltar(Wilkes), ? center drain
    By tinman.vt in forum Above-Ground Pool Construction & Repair
    Last Post: 08-12-2013, 12:28 PM
  2. bottom drain for 33 round above ground pool
    By kimkats000 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-09-2012, 08:02 PM
  3. In ground pool has pool drain cover plate trying to poke through the liner
    By ocgamer in forum Pool Equipment & Operations
    Last Post: 07-01-2011, 06:38 PM
  4. How far below the skimmer do you drain your above ground?
    By ElleM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-10-2007, 02:43 PM
  5. installing a center drain
    By rustin in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2006, 11:56 AM
