Results 1 to 10 of 17
Thread: Should I change my filter sand?
    Aug 2012
    Nashville, TN
    Default Re: Should I change my filter sand?
    Email sent, please share here if it helps Thanks, now hoping it clears water soon
    from email:
    Thank you. What main difference do you see? I thought sand is sand right, esecially if it says pol filter sand on the bag. To me it looks more coarse than the pool store sand I bought today. Wondering if that's why my last pump burned out.
    Because the filter sand was still damp, it was a bit hard to compare. But what I noticed was that the largest visible particles in the Quikrete were larger than the largest particles in the than the Palmetto sand. Filter sand is *supposed* to be evenly graded, with 90+% of the particles ranging from 0.018" to 0.020". Honestly, neither sand appeared to meet that specification to me, but the Palmetto sand seemed a bit finer, and I know from experience that fine sand produces clearer water than coarse sand.
    "Sand to be No. 20 standard silica (uniformity coefficient not greater than 1.75) .018-.020 in diameter particle size"
    http://www.pentairpool.com/pdfs/TritonIIOM.pdf
    "Grain size 20/40 mesh is most widely used. 90% of the sand is to fall within the specified particle range. Not more than 1% of the total sample
    can fall on the first or last sieve in the series. Clay and silt size particles >105 microns are removed with the processing, as well as weak and crusted grains."
    http://www.eqb.state.mn.us/documents...d%20report.pdf
    Aug 2012
    Nashville, TN
    No no, the samples were both un used, the Quickrete stuff was from inside the bag, leftover stuff I didn't use. Both bags had some condensation in them though, but this wasn;t sand that came from my filter.
  1. When is it necessary to change sand?
    By debdevero in forum Pool Equipment & Operations
    Last Post: 04-21-2008, 12:17 PM
  2. If You're "thinking" It May Be Time To Change Sand In Filter
    By tenax in forum Pool Equipment & Operations
    Last Post: 07-24-2006, 11:59 AM
  3. When to change sand in filter
    By Islander2C in forum Above-Ground Pool Construction & Repair
    Last Post: 05-22-2006, 03:55 AM
  4. Change my sand??
    By faithfulfrank in forum Pool Equipment & Operations
    Last Post: 05-17-2006, 05:15 PM
