Yep, in the default settings, you can set you default pool size, bleach strength and unit of measure. It will switch the whole program from US (Imperial) to metric, or vice versa. Mainly implemented for our friends across the pond.
I'm thinking now that I should have the program check to see if the registry key is set upon start up, and if not, to force the inital setting of the defaults.
*** adds that to his list of things to do ***
Michael
