Results 1 to 4 of 4
Thread: Cloudy Water
    Apr 2014
    Lafayette, LA
    Default Cloudy Water
    I'm seriously ready to throw in the towel and call it quits - never imagined I would have this much trouble and it would be such a hassle.
    Long story short, had green swampy water coming out of winter. Have been shocking the heck out of out my pool for several weeks now and can't seem to clear it up. Water is now a cloudy blue (4-7 inches visibility).
    Here's my latest numbers with Intex's recommendations in parenthesis:
    Copper .4 (.1 - .2)
    Free Chlorine 5 (.4 - 1.5)
    Combined Chlorine 5 (0)
    PH 8.0 (7.4 - 7.6)
    Total Alkalinirty 150 (100 - 140)
    Calcium Hardness 150 (200 - 400)
    CYA 60 (30 - 50)
    Copper is high because I ran too many boost cycles on my SWG.
    18'x48" Intex Ultra Frame (6400 Gallons), SWG, 2500 gph sand filter
    BigDave's Avatar
    Jul 2010
    New Jersey
    Default Re: Cloudy Water
    After the algae is dead, filtration gets rid of the cloud. Even the Intex sand filter is pretty small to clean up after an algae event. How much would it cost to refill the pool?
    12'x24' oval 7.7K gal AG vinyl pool; ; Hayward S270T sand filter; Hayward EcoStar SP3400VSP pump; hrs; K-2006; PF:16
    Apr 2014
    Lafayette, LA
    Yeah, that's what I'm doing now. The built in drains (used with garden hose attachments) are useless because of the slope of my yard. I've been using the Waste setting on my pump to drain/refill, but only down to the intake outlet so that's a tedious process. Guess I need to find a way to get a longer plastic hose to feed directly into the pool from the pump so I can actually drain it. I wonder if the 1.5" Intex setting is universal - meaning can I just go to a pool store and get a hose that will fit? Not thinking clearly right now as I am suffering from pool rage!
    BigDave's Avatar
    Jul 2010
    New Jersey
    Do you have the Intex skimmer? I used to take the basket out and let the body of the skimmer sit on the floor to pump out the water when I had my Intex donut pool.
  1. Cannot Get Rid of Cloudy Water
    By ajb8898 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-16-2012, 02:33 PM
  2. Cloudy Water
    By w7ill4iam in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-09-2012, 03:27 PM
  3. Very cloudy water
    By wildhorse in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-28-2012, 10:25 PM
  4. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 08:04 PM
  5. cloudy water
    By johnburr in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-07-2006, 05:19 PM
