Results 1 to 10 of 15
Thread: Low to Zero Pressure in Filter
    Apr 2014
    Dallas, TX
    Default Re: Low to Zero Pressure in Filter
    Thanks, Mark. I am definitely running a 1 sp / 1HP pump. Since I replaced the pressure gauge, I guess I'll replace the release valve too. (The gauge screws in to the top of the valve on my filter.)
    One thing I did fail to mention is that I have an attached heater. I've never used it so I sometimes forget it's there. Would anything there be a possible cause?
    mas985's Avatar
    Pleasanton, CA
    No, the heater would not cause that problem. Heaters cause filter pressure to rise, not fall.
    If you are feeling strong flow out of the returns, then it is most likely something to do with the pressure gauge and/or location of it.
    Mark
    Here's a crazy idea: Could the passage to the pressure valve be partially blocked? If so, it would read low pressure, even with a new valve, yet the pressure at the returns would "feel" normal.
  1. Low pressure in filter?
    By mkelley in forum Pool Equipment & Operations
    Last Post: 07-13-2008, 06:30 PM
  2. help? filter pressure issue!
    By badutahboy in forum Pool Equipment & Operations
    Last Post: 06-21-2008, 02:20 PM
  3. Sand filter pressure
    By dannyboy in forum Pool Equipment & Operations
    Last Post: 06-15-2006, 07:04 PM
  4. Filter Pressure Q - is this too low?
    By rrands in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 11:31 PM
