Dave, that was my thought, too. A pressure gauge can be replaced easily and inexpensively. I think I'd try that first.
I put a new pressure gauge on as well.
Could you tell us more about the piping, pump, filter and any other attached gear?
I have a 48 sq ft pentair FNS plus filter, 1 HP one speed pump (not sure of brand), all PVC pipes. Also I have a Polaris booster pump that drives a Polaris 280.
Have you inspected the grids to verify they're not damaged? There isn't a valve set to bypass on it, is there?
kelemvor - I think some of the grids are definitely damaged. I didn't see any tears or holes but the inside manifolds (right term?) on several of them were broken or moved around a little. Needless to say, I've ordered a new set of grids. Stupid question - but exactly how would that affect the filter pressure?
Thanks again for your responses - I appreciate it!
Blocked or damaged grids would probably raise the filter pressure. But when the pump is running can you feel any flow out of the returns? Do you have a check valves on the suction side of the plumbing?
Mark
