Results 1 to 10 of 15
Thread: Low to Zero Pressure in Filter
    Apr 2014
    Dallas, TX
    Default Low to Zero Pressure in Filter
    Hello - I recently had a problem with my pump not priming fully and had zero pressure in my filter. I was able to clear out some junk from the impeller, cleaned out all the baskets and my filter as well. After putting everything back together the pump runs fully primed but the filter is still almost at zero. I also got a new pressure gauge. I have good flow coming from the returns and everything "looks" good overall.
    Should I be concerned about the low pressure?
    Thanks in advance!
    BigDave's Avatar
    Default Re: Low to Zero Pressure in Filter
    Perhaps the pressure gauge is shot?
    Apr 2014
    Dallas, TX
    I put a new pressure gauge on as well.
    BigDave's Avatar
    Could you tell us more about the piping, pump, filter and any other attached gear?
    Apr 2014
    Dallas, TX
    I have a 48 sq ft pentair FNS plus filter, 1 HP one speed pump (not sure of brand), all PVC pipes. Also I have a Polaris booster pump that drives a Polaris 280.
  1. Low pressure in filter?
    By mkelley in forum Pool Equipment & Operations
    Last Post: 07-13-2008, 05:30 PM
  2. help? filter pressure issue!
    By badutahboy in forum Pool Equipment & Operations
    Last Post: 06-21-2008, 01:20 PM
  3. Sand filter pressure
    By dannyboy in forum Pool Equipment & Operations
    Last Post: 06-15-2006, 06:04 PM
  4. Filter Pressure Q - is this too low?
    By rrands in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 10:31 PM
