Results 1 to 5 of 5
Thread: changing sand
    Apr 2014
    kentucky
    Default changing sand
    How do I change sand in an AquaTools AT3125B sand filter?
    Default Re: changing sand
    Why do you want to change it? Filter sand does NOT routinely need to be changed. Many of us have the same sand for 12-15 years without needing to change it. It does not wear out.
    Apr 2014
    kentucky
    I was under the impression that the sand grains rounded out and didnt work as effectively. I was told to change it every 5 to 7 years
    Not necessary.
    Quote Originally Posted by danhild View Post
    Actually, just the opposite is true. As the sand gets older and dirtier it actually filters BETTER than before. If you haven't seen an obvious rise in dirt in the water, your sand is doing just fine!
  1. Changing Sand
    By Cindy32tn in forum Dealing with Algae & Slime
    Last Post: 06-27-2012, 09:14 PM
  2. changing filter sand
    By jrtvols in forum Pool Equipment & Operations
    Last Post: 07-02-2011, 08:44 PM
  3. Changing filter sand
    By tado921 in forum Pool Equipment & Operations
    Last Post: 06-03-2008, 11:10 PM
