Thread: Killing black algae while pool is drained.
    Scottsdale, Arizona
    Default Re: Killing black algae while pool is drained.
    No opinions on this approach to rid my pool of the black algae?
    With black algae, the key is to scrape off the waxy surface layer with a wire brush to expose the roots of the algae underneath to high chlorine levels. Technically, you could do this without draining and just maintain a high chlorine level in the pool, but again the key is REGULAR brushing to scrape off the surface layers once or twice a day.
  1. Small Black dots in salt pool. Black algae?
    By jeanne3434 in forum Dealing with Algae & Slime
    Last Post: 04-06-2014, 04:58 PM
  2. black algae in pool
    By bluekiwi in forum Dealing with Algae & Slime
    Last Post: 10-10-2013, 01:40 PM
  3. Cloudy pool after killing algae
    By peyman84 in forum Dealing with Algae & Slime
    Last Post: 06-26-2013, 04:19 PM
  4. cloudy after killing algae
    By Bowfin in forum Dealing with Algae & Slime
    Last Post: 07-28-2006, 11:51 PM
