Results 1 to 10 of 21
Thread: Sizing a new pump
    mas985's Avatar
    Pleasanton, CA
    Default Re: Sizing a new pump
    First there are couple things to be aware of.
    1) There is no physical limit to the flow rate in pipes. The numbers that you often see are recommendations and not absolute limits.
    2) The flow rates posted on filters are maximums, not minimums and in most cases, filters do better at lower flow rate.
    3) Forget everything you learned about turnover. It just doesn't mater. You can run your pump as short as you like as long as you get enough chlorine in the pool. I currently run my pump only 4 hours per day and more than half of that is on low speed so far less than one turn per day. Every pool is different but most pools can get away with less than 4 hours per day.
    As for pump size, you did not mention any water features so there is really no limit on how small you can go. I have a 1/2 HP pump on a 20k pool as an example. Smaller pumps will filter water better and cost a lot less to run. However given the pump height relative to the pool, you might stick with at least a 3/4 HP. As long as you have priming valves or check valves on the pump, you should be ok.
    As for two speed pumps, yes they can save quite a bit in operating costs so that is something I would highly recommend.
    Mark
    lstinthot is offline PF Supporter Thread Analyst lstinthot 0
    Aug 2011
    No water features on pool. We put a check valve in last year. It still takes some time for the pump to prime, like there might be a minor leak on the suction side of the pump. I am going to take the Nature 2 filter housing out of the discharge along with the propane heater we do not use. This should lower the discharge pressure some and hopefully tighten up the closed loop.
    What are people's favorite 2 speed pumps?
    Thanks again.
    ~36,000g IG gunite -- 2Hp Pentair UltraFlow filter pump - replaced with 2 speed 1 1/2 HP ultraquite pump -- 3/4 HP vacuum booster pump -- DE filter --K-2006 test kit
    mas985's Avatar
    Pleasanton, CA
    There is very little discharge pressure when priming. Just look at your filter pressure gauge as the pump is priming. So changing that probably won't help much.
    The pump you have now is probably pretty typical of a high head pump so that is about as good as it gets for priming lift. I don't think another pump is going to be better. Most residential pumps have a max lift around 8' and even that is pushing it so the valves are critical when priming but may not always work well at 10'.
    I would fix the priming issue before moving to a different pump because that is not likely to fix the problem.
    Is the equipment pad elevated or does it sit on ground level?
    Does the pump basket drain when the pump is off?
    Mark
    Aug 2011
    The pump basket does empty when the pump is off. I am limping this pump along right now. It is so load you can hardly talk standing near it and I blew the lid off at the end of last season with a bad valve line up blowing the lines out. It will need bearings, new lid and plumbing work, so I figured I would get a newer efficient model that uses less power.
    We have a check valve on the suction side and on the discharge side of the pump. The valves are new. The plumbing is new on the suction side of the pump as well.
    I was thinking of removing the extra equipment on the discharge side to help lower discharge pressure thinking that would allow me to run a smaller pump.
    I currently am running a superflow by pentair. Is it worth rebuilding this pump? It has run many of times with loss of prime. Currently does not leak when it gets a good prime, which it can do with in 2 minutes.
    mas985's Avatar
    Pleasanton, CA
    In your signature, you have UltraFlow but in your post you said SuperFlo. Those are two very different pumps so it makes a difference. Which one do you have? If you don't know for sure, post a picture.
    Also, your pump should not lose prime when off so something is leaking air into the plumbing. Most likely it is the pump lid.
    Mark
    Aug 2011
    Good catch on the pump. It is an Ultraflow.
    The basket stayed full this morning after I shut it off last night. There is a lot of gurgling going on after we stop the pump. There is a minor leak on the discharge of the pump, I was waiting to fix it and fix it when I changed the pump. Is it better to fix it now, make sure the system is tight and working before bringing in a new pump? I know the pump lid is no good, it seals when holding it there when I start the pump but the ears to hold the lid down are all broken so when it stops it pops up and I put it back on the pump.
    mas985's Avatar
    Pleasanton, CA
    The UltraFlow is a high head pump so priming is probably as good as it gets with this pump. You can either replace the entire pump or just the motor. It usually makes more sense to just replace the motor if the wet end is in good condition and you don't need to change any plumbing. But since you have to change the plumbing anyway, it may make more sense to replace the entire pump. Either way is fine, it is basically an economic decision.
    However, when looking at a replacement, you need to focus on max head because that is the only thing you can go on for priming ability. The higher the pump head, the larger the impeller and more effective the pump will be at priming. However, in most pump lines, the max head is the same for the various HP ratings so you can lower the HP to save some on electricity costs.
    If you want to stick with Pentair, the Whisperflo is a good pump line but for priming reasons, I wouldn't go below 1 HP (full rated). So either the WFDS-4 or the WFDS-26 would be a good choice.
    BTW, where is your location and how much do you pay for electricity? A VS may or may not be a good solution for you.
    Mark
  1. Pump and filter sizing
    By wsommariva in forum Pool Equipment & Operations
    Last Post: 05-23-2011, 12:37 PM
  2. Pump sizing query
    By Sumo1 in forum Pool Equipment & Operations
    Last Post: 03-12-2007, 09:58 PM
  3. Question on PB's pump sizing
    By txborn in forum Pool Equipment & Operations
    Last Post: 10-27-2006, 02:26 AM
  4. Pump sizing for filter
    By derrikm in forum Pool Equipment & Operations
    Last Post: 09-18-2006, 08:05 PM
  5. Pump Sizing Question
    By liz+3 in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 10:45 PM
