Thread: Advice on Liner Repair for Closed Pool
    Default Re: Advice on Liner Repair for Closed Pool
    Try Boxer glue and, if you have it, a hunk of liner as a patch. I like to use a rubber tile roller to even the patch out. With the cold water, I think you'll be lucky to get it to stick. There are also self-adhesive underwater patches that may get you through until spring. I suggest you get a pair of wet suit gloves (stores with hunting and fishing gear sell them for winter anglers) so you can work without freezing your hands too badly.
    Apr 2012
    Massachusetts
    Thanks Carl. I'll see if I can find the Boxer Glue. I had some other underwater patches but it wouldn't stick. Wet suit gloves are also a good suggestion.
    11K gal AG pool with Hayward 1.5 HP Power-Flo pump; W. Cooper Industries Ranger Series Sand Filter Model RS1815 & the multiport valve model number is TM-12-L ; valve size on this model is 1 1/2", tank diameter is 18"
