I had to replace the "O" ring on the valve stem on my PacFab DE filter, suspect the valve is similar. I removed the top half and used a vise to slightly compress the spring so I could remove the pin and then remove the handle so the stem can be removed to replace the "O" ring. Be careful when compressing the spring assembly to not scar the face of the multi port valve assembly.
Also when reassembling make sure the handle is positioned properly as on my valve you can put it back together 180 degrees off, guess how I know?
Lube the new "O" ring.
Good Luck,
David
