Results 1 to 3 of 3
Thread: Hot Tub Question
    timmie is offline Registered+ Thread Analyst timmie 0
    manitoba, canada
    Default Hot Tub Question
    I have a hot tub and I live in Winnipeg, Manitoba. My pump goes on for about 3 hours at a time and I am not sure how to turn this down. My electrical bill last month was 213.00. Can anyone help me with this? I dont remember the pump going on for this long last month and my electrical bill was very low.
    Thank you for all your help
    Timmie
    Default Re: Hot Tub Question
    If your pump goes on for 3 hours a day, that's not the source of your bill. But if it's off for 1 hour, then on for 3, it could be. There's a timer somewhere on the system. Check with the manufacturer or your owner's manual for where that timer is.
    I'm not knowledgeable about hot tubs.
    Jul 2010
    Largo, Florida
    I was on vacation a few months ago and the cabin we stayed at had a standalone hot tub. That tub had a thermal sensor and would turn the pump and heater on whenever the water temperature got below the preset level. It's possible you've got a similar system, Timmie.
    Make sure your cover is on the tub securely, consider reducing the temperature it's set to when not in use quite a bit.
    Why is this thread in the china shop?
