Thread: Two speed pumps - how to control them (timer ?)
    Long Island, NY
    Talking Two speed pumps - how to control them (timer ?)
    Hi all,
    I am considering replacing my old 1 HP pump (on a timer) with a 2 speed pump (e.g. Pentair WhisperFlo WFDS24) to reduce my electric bill. How do I control that ? Do I need a special 2 speed timer ? Or has the motor 2 plugs ?
    Thanks a lot
    Patrick
    Toronto, Canada.
    Default Re: Two speed pumps - how to control them (timer ?)
    I am interested in this as well. It would be nice if you could automate it to run on low speed for X hours and on high speed for Y hours. Anybody know how to do this and with what devices?
    Mesa, AZ
    My 2-speed pump has an Intermec 2-dial timer. One turns the pump on and off, the other turns it from high to low. In my installation I really only use the speed switching timer because I run the pump continuously, switching to high speed for a few hours a day to operate the in-floor cleaning.
    mas985's Avatar
    Pleasanton, CA
    I have an Aqualogic controller with a built SWCG controller. It has two time cycles and for 2-speed pumps, the first is for high speed and the second cycle is for low speed. A pretty good set up for 2 speed pumps and a SWCG.
    Mark
  1. Advice on Variable Speed Pumps for Spa
    By JohnASmith in forum Pool Equipment & Operations
    Last Post: 07-01-2013, 03:37 AM
  2. Question on 2 speed pumps
    By Robert53 in forum Pool Equipment & Operations
    Last Post: 03-24-2012, 09:59 AM
  3. 2 pumps in series used like a 2-speed pump
    By ChadH in forum Pool Equipment & Operations
    Last Post: 05-22-2007, 12:07 PM
  4. Autopilot Total Control Timer ??
    By fjava in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-10-2006, 02:38 AM
  5. Are two-speed pumps worth it? HELP
    By Ken and Laura in forum Pool Equipment & Operations
    Last Post: 07-08-2006, 12:51 AM
