Re: First full pool test
CH is VERY high, but with your TA low it may be OK. Ben or the others may be able to find a way to lower CH short of dilution to prevent scaling. But the lower TA will help keep from triggering that.
If your CYA is really 110 (again, dilution can help with that) you'll need to maintain FC between 8 and 15ppm, and shock at 25 or more (as you are). The good news is that with your FC in that range you probably won't need much to maintain those levels.
