In that case, you might need to find the board and install it yourself. If you're comfortable doing a little electrical work, that is.
Disconnect it from the power source, open the box and examine the panel circuit board. You will probably find a part number printed onto the circuit board its-self. Then you can search the internet or call them and ask about parts. Replacing a circuit board is usually very simple, just take pictures before you disconnect wires, and put the replacement in where the original was.
If you can take a picture of the board, and post it, we may be able to help you id it.
4 out of 3 people have trouble with fractions.
Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
